Shortcut for conductor lite view?
La Tenaille
I'll allow a right click 'midi learn' on the 'show normal' button.
So you will be able to create any key affection to show the window.
La Tenaille
Great, merci Olivier
La Tenaille
It works fine, thanks!
More conductor thoughts:
I note that the 'show' input on the conductor object always shows the conductor, not the conductor lite, regardless of which window was enabled.
Seems like workspaces that contain a conductor object always start up with conductor lite window open.
I wish I could resize the conductor lite window. I don't need so much width, and those little buttons up top are too small for a touchscreen.
Better yet would be a conductor object that could appear as a regular list in the touchscreen window.... a floating window is not helpful in a touchscreen environment.
But I think if I can always get the conductor lite window to appear and disappear with an external midi control, that will work okay.
cheers,
-eric
cheers,
-eric
interesting,
but you can take a look on the Big Conductor example in the Touch Screen Library.
I'm sure it rocks for you!
It only seems to show 7 presets, is that right? The great thing about the conductor is that it holds any number of presets.
I built a similar component the first day I had usine (minus the 7 presets--but with a fader to control preset number instead--and a text display) and it is very nice. But I wanted a better way to select presets by name.
It will do for now. But I hope the new touchscreen combobox behaviour will also work with the conductor. When I'm improvising, I like to see a lot of patch options laid out for me--I don't always know in advance what sounds I'll want to use!
well, I'll work something out. I'm sure there are options I haven't considered.
