Start and end of a sample
Unread post by cmodica » 21 Jan 2009, 10:07
Something like Ctrl Click and drag to select the part of a sample to play in the Wave Display Module ....
It will be faster than select start and end in two times.
Unread post by senso » 22 Jan 2009, 18:37
I'm not sure to understand.
can you develop?
Unread post by cmodica » 23 Jan 2009, 09:37
Yes, sorry i try to develop.
To select the part of a sample to play i had to drag on the left of the wave display window to select the begining (the start point), and after i had to drag on the right of the sample window to select the end point. So now i can for example play in loop just this selected part.
If i can do that in one time by draging the mouse on the part that i need, like to select few lines in a text editor, it will be very faster.
I hope it is more clear ....
Unread post by senso » 23 Jan 2009, 17:20
ok I understand now.
since the range select is not implemented it's not so easy but not impossible....
Unread post by cmodica » 23 Jan 2009, 18:13
Ok,
thank you Olivier.
