Is there a reason why this is illegal?
Basically every control I have is in a subpatch! I'd like to be able to show and hide controls without having to create another sub-subpatch for each control. Especially since subcontainers don't snap to grid, and therefore are difficult to layout accurately.
Thanks!
-eric
invisible controls in subpatch
Each control can be hidden in real time, using the 'visible' inlet.Basically every control I have is in a subpatch! I'd like to be able to show and hide controls without having to create another sub-subpatch for each control.
To display the 'visible' inlet, just click on the 'white square' in the module (expand command)
clicking somewhere in the parent interface builder (container) provide a snap to grid on the child containers.Especially since subcontainers don't snap to grid, and therefore are difficult to layout accurately.
I know it's not automatic, and I'm working to solve the pb.
Thanks for the tip on snap to grid.
When I set a control in a subpatch to invisible, I get:
subpatch control can't be invisible
scrolling endlessly in my output......
However, it did just occur to me, I could set its visibility to 'control panel' instead, as a workaround....
that will simplify my life, and make the tiny subwindowing problem go away....
oh wait, I recall that doesn't work, because the control forgets its size and placement in the layout.....
Users browsing this forum: No registered users and 102 guests
