Usine still has the hidden keywords (e.g. type quit inside 2 seconds and usine exits just like that).
I recently activated this by mistake entering in the word quit and the text box was not open as I thought.
Luckily not in a live performance !!!
I never use these keywords and they are a lurking danger to me.
Please could we have a new EXPERT menu option to disable these keywords.
I also noticed we have ctrl-Q which will quit Usine without confirmation.
Could this be added to the Key Learns menu so it can be disabled ?
The other suggestion would be an EXPERT option "Always ask for confirmation before Quit".
Simon.
hidden keywords
The option to disable hidden strings is already available in /workspace/kiosk/ settings.
The [ctrl+Q] ask for confirmation if the wkp has been modified or just clicked.
Oh yes, in the extra config INI files I expect you can put
disable hidden strings=1
Not tried it yet though.
Looks like those extra INI files could be useful ...
Simon.
Simon.
Users browsing this forum: No registered users and 131 guests
