I think this is more a bug than a suggestion...
I would think that the parameters of a VST should be fixed and internally never be forced to
change size. I have a tendency to get the horse before the cart...and I end up forcing the
size of the VST.........
I can find only fixable by recreating the VST, or forcing a new size into the array with a known specified value.
Could you block array re-sizing on the inputs of the VST?
I can't think of any value of being able to resize the VST itself.
Maybe a prevent-resizing module would be of good value to create (maybe even beyond this issue)...but it seems like that unless there is a reason for the resizing on the VST...it seems more like a bug.
-s
Prevent VST Inputs from Resizing the Array
Yep, I have also experienced this so a +1 from me.
Drives you nuts doesn't it guru? You led me back down that path with that post, completely starting to re-hash and remember...Now you have me chompin' at VST array and ..... D@&n! I lost the VST Array again, mumble grumble...resize...haha
-s
-s
It was definitely a head scratcher the couple times it happened for me. If i make sure the plugin array out is connected before connecting the plugin array in, all is well.. Well except for the other little things that drive me nuts when I hit a wall that prevents me from being able to make something work how I want it to , haha
