Would it be possible to add a Master Solo indicator/switch in the dashboard, preferably with a defeat all function? It would light up when one or more tracks are in solo mode, and if turned off all soloing would be cancelled.
A similar Master Mute could also be useful sometimes.
Master Solo/Solo Defeat?
Yes, a solo indicator.
But I'm not sure the dashboard is a good place.
Let me think about it: create a small panel near the master in/out?
Well, I proposed the dashboard since there's a little space left under the midi/osc indicators, but alongside the master fader would also be ok.
An added "bonus" though with placing it in the dashboard, is that the button(s) would still be visible if one uses the interface builder for the patches and reduces the size of Usine's main window to show just the dashboard.
Ok, I will see.
thanks for the feedback
Users browsing this forum: No registered users and 69 guests
