previewing a scene to conductor
joffo78
Unread post by joffo78 » 25 Mar 2010, 10:24
Hi
i've juste finished my sequencer for theatre perform (http://www.sensomusic.com/forums/viewtopic.php?id=2065) and something is seriously missing.
when i recorded my scenes step by step to conductor i can't preview or modify the content whitout recall them.
Do you have some suggestions ?
JF
Unread post by nay-seven » 25 Mar 2010, 13:18
not sure to understand your problem...
when you edit a change in your scene, you preview it in the same time...no?
joffo78
Unread post by joffo78 » 25 Mar 2010, 13:44
yes but if i want to modify a scene without playng it, how can i do ?
Unread post by nay-seven » 25 Mar 2010, 15:32
if you switch off all your tracks ( but not the main audio engine of Usine ) you can edit the scene without playing it ,
then just before save it put the tracks on again..?
joffo78
Unread post by joffo78 » 25 Mar 2010, 18:27
yes but that i want is when i'm playing a scene i could previewing another to modify it
Unread post by nay-seven » 25 Mar 2010, 19:22
no, the conductor can play only one scene in the same time...
Users browsing this forum: No registered users and 109 guests
