HH5 plugin module bug
I have found a bug in HH5 with the plugin manager module.
When a VST window is open it is always on top of everything.
So if the VST puts up a message box (e.g. Omnisphere loading multi warning box) it is stuck behind the VST window
and cannot be clicked on. Also when Omnisphere opens a browser to show the current midi assignment that is stuck behind
the VST window too and cannot be seen.
This does not happen on HH3 so is not an issue with the VST.
Simon.
Simon.
Anyone know how to report a bug in HH5 ?
Used to be support@sensomusic.org
Is it support@brainmodular.com ?
The bug reporting forum has been locked for a few days.
OK, I have sent it to support@brainmodular.com
yes, that's correct
jacob raggers
- New member
Simon,
HH4 has this problem too. And its not only with Omnisphere, Kontakt etcetera behave the same. I solved it with a little app called 'Turbo Top'.
Works for me okay (Windows 10)
Oh, I missed out HH4. There was a similar problem in earlier versions that was fixed.
If the problems are with various VSTs then it is obviously a Usine problem.
I am sure we can get a proper fix sorted for HH5.
Well I raised a bug report when I think Senso was on holiday.
I sent a reminder but still not heard back about this bug.
Simon.
Simon.
Users browsing this forum: No registered users and 95 guests
