I was wondering if it was possible to get the output of the Oscilloscope module to be used in "high definition mode".
Thank you
Oscilloscope definition
maybe an idea for the suggestion forum ?
be sure to also check that use low graphic quality is disable in the setup/global
Thank you for your answer. I've tried changing the graphic quality but it doesn't change a lot.
I'll suggest it.
I'll suggest it.
Like for every module in Usine, the output definition is linked to the size of the GUI. The more the size is high, the more the output definition is increased.
Hope it helps.
Hope it helps.
Here a workspace the user rlgsbt send me ( he has temporary difficulties to access the forum)
Users browsing this forum: No registered users and 204 guests
