Arturia Spark and Hollyhock
noise2sine
Unread post by noise2sine » 12 Sep 2018, 14:54
Anyone is using Arturia Spark LE in Hollyhock ? I have problem with the Spark controler to be reconize when i'm in Hollyhock ! The plugin in a patch is working fine, but i can't make the controller working. I have checked the midi option and everything seems fine. Do i need to make a specific patch for having the controller working ?
I have the same problem with the Arturia beatsetp and the keystep !
With the keystep , i can use it as a midi keyboard without any problem but the keystep won't be synchro with Hollyhock :( When i start hollyhock the keystep should be synchro and starting but at moment it's doing nothing !
Thank you
sephult
Unread post by sephult » 13 Sep 2018, 12:31
I've used the spark LE for quite some time, I believe I remember it is tricky.
One thing is the engine has to be started in order for the controller to recognize, and I think also for the MIDI you need to find the device
and make sure your MIDI clock is set to output.
I'll try mine out here in a little bit see if I can give any pointers.
-s
sephult
Unread post by sephult » 13 Sep 2018, 23:05
Hi noise2sine!
I just hooked up my Spark LE, and yes you must have the engine running, as well as press the connect icon manually sometimes to connect.
I think I've had issues too where I had to disconnect and reconnect, but hopefully that helps.
Let me know if you need help I have mine out on the console if you need me to check anything. BTW I am Win10 x64
noise2sine
Unread post by noise2sine » 14 Sep 2018, 20:10
Hello !
Thanks for yr advices, i will try that way and let you know .
Thanks again
noise2sine
Unread post by noise2sine » 01 Apr 2019, 21:22
I didn't find a way to make it work with the controller yet ! ihave tried many ways but without success ! i have started the engine and then the connect button , thicking input and output in the midi control panel....
In Ableton in order to make it work,each input and output must not be selected ...that Spark works fine, in Hollyhock i don't know :)
thanks
noise2sine
Unread post by noise2sine » 10 Jun 2019, 23:38
i didn't find a solution yet for making the SparkLe working ! Maybe someone can give explication for making it work ! such a shame because it's a good tool and in Hollyhock it must fantastic !
sos :)
Unread post by nay-seven » 11 Jun 2019, 12:25
Hello, generally, you don't need to activate the audio engine to have a controller recognized
so a check list:
- which Usine version have you use? ( have you check the last version ?)
- PC or Mac? (Os version?)
- don't use Usb hub to connect the unit
- Connect the device and start Usine after ( normally not necessary, but for test)
- When you rescan the devices in the MIDI tab , what's happen exactly?
noise2sine
Unread post by noise2sine » 16 Jun 2019, 20:26
Hello Nay,
I'm using Windows 10 and it's updated,The version of usine i'm using it's the Hollyhock 3.0.88 64 bit . I can see the device in the midi option and i have tried many ways for connecting it without any success.
The Spark is connected without any USB hub .
Please i need help because i have a gig next week !!! :)
Thank you !
x.iso
Unread post by x.iso » 16 Jun 2019, 20:39
have you tried to turn on/off clock/timecode in midi device's settings?
Also, what does manual says exactly? plugin just tells that 'some' midi connections need to be turned off.
noise2sine
Unread post by noise2sine » 16 Jun 2019, 21:18
Yes that's what the manual said and i have turned the spark in and out off in the device panel . I can't find other input or output !
Unread post by nay-seven » 16 Jun 2019, 22:12
Now, if you open the trace panel / right click / activate the MIDI IN Trace what kind of message do you see ?
noise2sine
Unread post by noise2sine » 16 Jun 2019, 22:31
Thanks it's working now ! i saved and reload the project and the connection failed ! What the hell is going on !!!
x.iso
Unread post by x.iso » 16 Jun 2019, 23:11
As sephult mentioned, it might be because engine needs to run for VST to work properly and connect to device. read his posts above
noise2sine
Unread post by noise2sine » 16 Jun 2019, 23:22
Yes thanks i missed that i had to disconnect and connect the unit while Spark is running ! Working for now ! thanks for your advice ! very useful!
Users browsing this forum: Bing [Bot] and 125 guests
