midi foot switch
http://www.icon-global.com/Controllers_ ... -Board.htm
switches are a little noisy but it work fine !
multiphone
Hello Kenan,
I Use the switch input of my BCF 2000 (If du you have one), only one switch but for me i'ts enough.
Best
Best
damstraversaz
I've a second hand FCB1010, which was cheap but do the job.
It is a little heavy, but with lot of switchs
I'm back...
www.gillesdimanche.com
And if you like DIY and practice a little soldering, an old usb joystick can also be a cheaper solution...
hi ,
the cheapest , a dance pad connecting in usb ,
I use 4 for live musicwith HID module ,[img]C:Documents and SettingsgéraldBureau2nd-dance-pad.jpg[/img]
10 switch in each mat I you want a patch, no problem
gercha
gercha
L'orchestronique - foSolo
http://www.arbre-canapas.com/l-orchestr ... ideos.html
@gercha : you'll need to upload your picture before use it in your post, check here if needed
Thanks for the answers guys !
Actually, it is for a single concert, the BCF 2000 is a great idea, I can easily have one lent for this concert.
Kenan
Kenan
multiphone
And if you want you can connect two guys on the BCF 2000 : Switch and expression pedal .
I Use a Korg EXP-2 as expression one.
http://www.thomann.de/fr/korg_exp2_expression_pedal.htm
Not very cheap but very efficient.
Best
Best
Users browsing this forum: No registered users and 167 guests
