Exporting Usine patch as VSTi plugin?
UsineHeaven
Unread post by UsineHeaven » 03 Jul 2011, 05:12
One thing that I can try in Usine VST free version is its VSTi ability. My goal is to create a patch in Usine, including VSTi, and then export/save it in VST format for use in Cubase.
Possible?
Cheers.
Unread post by nay-seven » 03 Jul 2011, 08:49
no, but why do you need to export..?
you can use Usine VST ( with your patch ) directly in cubase..?
UsineHeaven
Unread post by UsineHeaven » 03 Jul 2011, 09:09
Well in that way I will always need do open Usine 2x2 or similar first, THEN load the patch. It would be much more flexible if I could load a Usine patch or project directly as a VSTi and control it from Cubase in that way.
Fore example, if I create a 3 different VSTi base Usine patch's that I want to use in Cubase. It would be easier to see those 3 exported patches or projects as separate units in Cubase VST list. Just load and play :)
Cheers.
Unread post by nay-seven » 03 Jul 2011, 09:23
yes but Usine is not Synthedit or Synthmaker...!
and once you have create your project, you save it and next time you'll have nothing to do more, usine vst will open with his patch...?
UsineHeaven
Unread post by UsineHeaven » 03 Jul 2011, 10:05
Sorry, misunderstanding. What I', missing is ability to open them directly from Cubase, without to first load Usine VST and them open them from Usine container. Actually, I can live with that, but just if could open saved projects or patches directly. For example as Helix in the Usine demo VST folder.
Unread post by nay-seven » 03 Jul 2011, 10:22
ok, so you want drag & drop a Usine patch directly in your sequencer to open Usine VST..?
if so it's not possible right now
Unread post by 23fx23 » 03 Jul 2011, 14:57
Mmm i use easine in ableton. If i make 3xd differents live tracks. On each of them there is one easine with is own patch, when saving and reooening live document it recall all 3 directly here, no need to go and open the patchs
UsineHeaven
Unread post by UsineHeaven » 03 Jul 2011, 21:50
23fx23 wrote:Mmm i use easine in ableton. If i make 3xd differents live tracks. On each of them there is one easine with is own patch, when saving and reooening live document it recall all 3 directly here, no need to go and open the patchs
That is my goal too. But, for example, can those Usine patches appears as following in Ableton plugins list:
Usine_Pro53
Usine_JV
Usine_M1
Or do you need to always first open a Usine container in DAW and THEN select patch?
Cheers.
Users browsing this forum: No registered users and 262 guests
