Hello again, sorry for being so boring, but I'm really close to finishing the spanish manual, so...
I noticed a pair of inconsistencies on this page related to features that don't behave exactly the way the manual says.
* the manual tells about the number of direct access buttons at 4, but tells nothing about the max number of buttons, that is, 8 buttons.
* the manual explains a method for recalling the memory from buttons that doesn't work. I click the button once and nothing happens. Or maybe it´s me. Is this a typo or it is a bug?.
greetings,
Floego.
getting trouble with global interface builder page
you're right about numbers of button
about recalling position , this is working for me here ..?
you move the scroller bar , double click on a button,to memorize it , move and memorize an other..then a simple click must recall them..?
thanks anyway for your eagle eye..
Hi!,
My fault for not understanding precisely what the memorize button was for ;p
Now I see:
the buttons works memorizing some partial view of the workspace when the interface is longer than the size of the window or exceeds the horizontal size of the screen.
I thought the buttons where used for memorizing the position of the patches in the screen.
thank you for answering,
Floego.
Now I see:
Floego.
Users browsing this forum: No registered users and 90 guests
