tremoresque
drakh
Unread post by drakh » 11 Dec 2013, 15:04
this is FX pansion Tremor inspired drum sequencer (just sequencer). What is missing at this time - note repeat control, and osme optimisation for notes sequencer is needed - i will probably try to use sequenced switches for note generation, sou you will not need to change notes sequencer when configuring the note for your drum machine of choice.
Any advice for how to do that? note repeat and sequenced switches for note generation ?
lytz1
Unread post by lytz1 » 27 Jan 2017, 22:13
Does someone know how to sync Tremoresque to the main timeline/song?
I can't get it to sync up with everything else. It just does its "own thing".
tL.
lytz1
Unread post by lytz1 » 29 Jan 2017, 03:24
Nevermind. Got it.
