Play List patch (aka One Note Triggering)
Unread post by bsork » 09 Jul 2008, 22:04
Inspired by ethnix73 (see http://www.sensomusic.com/forums/viewtopic.php?id=844), I have created a patch that lets you define a list of "sounds" using either a normal sampler, a grain sampler, or MIDI one at the time. A "sound" (or entry as I've called in the patch), is for instance a file number with play mode, pitch, reverse on/off, start/end points, and level.
Even if the play list idea is of no interest to you, you might find some use for the sub-patch/script that maintains the list. With it, you can store sets of parameters within a single array, and add or truncate entries at the end, as well insert, update and delete entries from the array.
(...and if anyone thinks this last bit looks like some home-brew SQL, there's also a select button within the patch :P...)
moody33
Unread post by moody33 » 10 Jul 2008, 00:31
Thanks for the script ! It rocks!
I don't know if will use the patch, but the script is already in my favorite.
I was asking Oliver about a module that could record values each time they change and then write them in txt file. Do you think that you could make one? A kind of "trace value" module with the ability to save as text file?
Thanks.
Unread post by bsork » 10 Jul 2008, 08:14
Thanks, I appreciate that it's appreciated! And I'm not sure if will use it myself - not in it's present incarnation anyway.
I don't think it would be hard to create such a module. Somewhere in the Demo folder, there's a script with an example of how to read and/or write to a text file (I don't quite remember), that I could use as a starting point. I think the parameter list could look something like this:
write (switch)
filename (txt)
datavalmode1..4 (off, write, check)
dataval1..4 (data)
textvalmode1..2 (off, write, check)
textval1..2 (txt)
arrayvalmode1..2 (off, write, check)
arraytval1..2 (array)
I guess having more than 1 value input would come in handy? You could for instance have some time info (seconds, bar/beats, position or whatever) as val1 with valmode1 = write, while the other value(s) are checked for any changes. When changes occur, a new line would be written to the file. I think I'll go for semi-colon to separate the values on each line. Text values would also be enclosed in double quotes, while array index numbers and a colon would precede the actual value.
That should cover most situations, wouldn't it?
Unread post by senso » 10 Jul 2008, 09:29
as usual, Bsork a master piece. You're a killer man!
moody33
Unread post by moody33 » 10 Jul 2008, 11:57
Woooo..Bjork! I wasn't asking for a very complex script!
I only want 1 value input with change detection . Then the script should write values like this ( without comma) :
0
12
45
78
99
I plan to use the list combo to read the file ( Oliver plan to write a string to integer module wich one is needed to convert text infos ) after saving it in a text file . After, I want to copy paste into the list combo module.
Of course, feel free to imagine more complex things! I like it ! Your suggestion could be very useful . it's up to you , if you have time of course.
Unread post by bsork » 10 Jul 2008, 12:13
OK, I think I'll start with the simpler script you're asking. Most of it can be reused for something more elaborate, and maybe I even get around to write something that goes the other way..? That is, reads from a text file and output data.
moody33 wrote:Woooo..Bjork
BTW, even if I'm going to be on Iceland in a couple of weeks, I'm neither Icelandic, female, famous nor a talented singer... ;)
ethnix73
Unread post by ethnix73 » 10 Jul 2008, 12:13
Thanks Bsork...My patch is not yet ready.
Seb.Dub
Unread post by bsork » 10 Jul 2008, 12:17
Hi Ethnix73, I would like it if you uploaded the patch to the add-ons when it's finished. Your angle on solving the issue is so different from mine that I think it's really worthwhile to have both solutions available.
moody33
Unread post by moody33 » 10 Jul 2008, 12:25
Good idea for "the thing that do the other way"!
What? You're not Bjork? What a shame. I was searching other script request only for talking to you my princess...
I'm sad now.
Unread post by bsork » 10 Jul 2008, 12:53
There, there... You'll get over it in time. :)
Unread post by bsork » 10 Jul 2008, 23:51
Users browsing this forum: Bing [Bot] and 16 guests
