"Switch to increment/decrement" add on not working correctly on V5
maxdis
Unread post by maxdis » 07 Mar 2010, 21:30
Hi
I've found that some patches using the "Switch to increment/decrement" add on (http://sensomusic.com/download.php?file ... crDecr.pat ) are no longer working correctly since the V5 .
Anyone found the same?
Unread post by bsork » 08 Mar 2010, 08:25
That's one of my add-ons. I'll try to have a look at it tonight.
Unread post by bsork » 08 Mar 2010, 22:35
Hi, I created and uploaded another version using the Clock subpatch and the new switch grouping function. Check if it helps to change to the new version in the patches where you have trouble.
maxdis
Unread post by maxdis » 10 Mar 2010, 13:06
thank you! I put it on my patch, and it seems to work fine, so far :-) But I had to fix a little bug: both the "Increase" and "Decrease" inlets actually increase the number, so I've put a "-X" module after the decrease inlet
Unread post by bsork » 10 Mar 2010, 13:20
It works as it should with the latest few versions. I don't quite remember which version introduced selectable on/off values for the switches, but I guess you're a couple of versions behind. :)
Users browsing this forum: No registered users and 116 guests
