my liveset with hollyhock
How do you use usine?
drakh
Unread post by drakh » 29 Oct 2014, 12:49
this is my liveset performed using Hollyhock
http://www.mixcloud.com/ctrpt/ark-hd-li ... ason-edit/
here is a screenshot of main drums rack. As drummachines it uses two D16 nephetons and two D16 drumazons (so two 808, a 909 drummachines)
they are feeded by different pianorolls that two matrices on the bottom solves the routing from pianorolls to drummachines.
upper matrices are routing different outputs from the drum machines to effects (for each matrix there is one "ghost" matrix which takes array otuput to array input to solve stereo) and after that you can feed one effect to another one, to make glitchy processed sounds.
ceasless
Unread post by ceasless » 31 Oct 2014, 17:24
Drakh, I'm digging this mix!
pumeus864
Unread post by pumeus864 » 31 Dec 2014, 09:17
So good ! Aller!
etui xperia m2 etui sony xperia m2
Users browsing this forum: No registered users and 91 guests
