Since the changes my Usine HH3 has decided it is not authorized and I cannot authorize it.
I have got a new password and changed it back to my old one on the new forum.
When I enter the details in the settings box, it always says "you are not correctly registered".
Also, the username box appears corrupted with:
<p>The forums are temporarily down for maintenance. Please try again in a few minutes.<br />
I suppose existing Usine configs are trying to connect to the old website - how are you going to get round that ?
Anyway, if this is not going to work for a while, please send me an activation key I can use instead.
Simon.
cannot authorize since forum changes.
fixed now.
you must enter your old (sensomusic) password.
sorry
sorry
filipsijanec
- New member
Hi, I am having troubles with this too. Tried both paswords the one Sensomusic set to me originally and the one I have created subsequently for Sensomusic forum. In addition i have the software up and running on my laptop but i have tried to run it on my new iMac too. I figure this might create some issues. If so is there a way to unactivate the software on my laptop while using it on iMac?
Filip
Filip
You can install Usine on several machines. There is no limitation.
Please send a mail to contact@brainmodular.com
Users browsing this forum: No registered users and 3 guests
