Usine Hollyhock II 2.0.081e update
Announcements
Unread post by senso » 11 Jan 2016, 21:57
[large]2.0.081e[/large]
Compatibility with OSX 10.11 El Capitan
Upgrade recommended if you encounter troubles with Audio and MIDI setup or you use OSX El Capitan.
bugs
- few bugs in the Audio - MIDI devices manager
- few bugs in the DMX plot panel for 16bits fixture parameters
Unread post by sm_jamieson » 12 Jan 2016, 12:05
Does this include a fix to the multi touch callbacks in the SDK ?
Or is a new SDK release required for that ?
Simon.
Unread post by senso » 14 Jan 2016, 00:52
the SDK will be available in few days.
sorry for the delay.
Unread post by oli_lab » 14 Jan 2016, 10:05
is it relevant for winblows ?
thanx
Unread post by sm_jamieson » 20 Jan 2016, 01:23
The 32 bit windows version does not run for me at all. Nothing appears on screen (not even the splash screen), and the Usine.exe process just sits there at 0% CPU and some small amount of memory.
Simon.
sephult
Unread post by sephult » 20 Jan 2016, 07:53
I can confirm 64 bit windows works here
Unread post by nay-seven » 20 Jan 2016, 08:36
32 bits version works here too, any chance your download was corrupted ?
anyway a new update is coming
Unread post by sm_jamieson » 20 Jan 2016, 10:40
It works on my other computer, so must have been a corrupt download.
Simon.
Unread post by sm_jamieson » 22 Jan 2016, 15:27
My virus checker was getting stack analysing the file for some reason. When the virus checker was disable and re-enabled everything was OK ;-)
