Usine 4.20
Announcements
Unread post by senso » 09 May 2009, 18:17
[4.20]
The first non-beta release!
Also the free version is available for download.
Usine free is fully functional except that you can't edit sub-patches and there is no dual core optimization.
improvements
- the delay value in the delay module can be set in number of samples
- new smooth speed option in the delay module (fast, medium, slow)
- latency estimation outlet (in number of samples) in the VST plugins. Can be used to create a latency compensation.
fixed bugs
- sometime the remote midi assignations aren't stored in the patch
- various errors in process midi out messages from midi vst plugins
- bad refresh background bitmap layout in the SDK
- slow drift in the pianoroll in 'play button' mode
- copy/paste errors in the pianoroll
Unread post by 23fx23 » 09 May 2009, 18:28
cool cool thx samples and latency estimation supper great
stanlea
Unread post by stanlea » 09 May 2009, 23:56
Small bug at first run : "No disk in drive D:" I think that the demo song adresses files on a D: drive.
edit : same problem when I want to load a module...
Am I the only one to deal with that ? Or did I miss an evidence, as I usually do ?
You know my name (look up the number)
runagate
Unread post by runagate » 10 May 2009, 03:20
very, very nice!
stanlea
Unread post by stanlea » 10 May 2009, 17:15
Hem... do I need to make a bug report ? Still "error scanning D: "
Unread post by nay-seven » 10 May 2009, 18:20
@stanlea :
can you check setup/interface/folder/patch library path......?
must be here...;-)
stanlea
Unread post by stanlea » 10 May 2009, 18:42
nay-seven wrote:@stanlea :
must be here...;-)
nope, already checked, first time it happens
thanks, anyway, nay
Unread post by senso » 10 May 2009, 19:48
@stanlean: this pb appear sometime on some computers. You're right, its because the files make reference to a location on the drive D:. But on most of computers if the D: is empty on doesn't exist it's not a pb.
I'll post the 4.20a soon where all the references are corrected.
stanlea
Unread post by stanlea » 10 May 2009, 21:06
Ouf ! I'm not so stupid, after all. A workaround is to insert any cd in drive d: to access the patches, but Usine can't still find the samples. Does it happens if the main drive is another label than c: ? Mine is F:
nofish
Unread post by nofish » 11 May 2009, 10:08
Thanks a lot, Senso !
ethnix73
Unread post by ethnix73 » 11 May 2009, 12:43
Thanks Mr Senso
Seb.Dub
Clearscreen
Unread post by Clearscreen » 12 May 2009, 03:16
i can't keep up with all the updates! i love a developer that keeps that far ahead of things :)
Users browsing this forum: Bing [Bot] and 78 guests
