Usine Hollyhock II 2.0.067 RC11 update
Announcements
Unread post by senso » 17 Apr 2015, 09:50
[large]Usine Hollyhock II 2.0.067 RC11 update[/large]
Important download, the 066 was definitively a bad version.
You should upgrade it.
improvements
Ticket #000048 : the Skip Over option deleted
up to 192 audio channels sound card supported
corrected bugs
Background images are not loaded correctly
Various possible UI bugs
MidiOut error messages in sub-patches
Some files are missing in the LEAP Joggle XY multi patch
Unread post by senso » 17 Apr 2015, 18:07
[large]Usine Hollyhock II 2.0.067b RC11 update[/large]
corrected bugs
E1001 invalid Event error sometime displayed
Randomize sequenced Steps modules works only if the module visible
sephult
Unread post by sephult » 17 Apr 2015, 18:49
067b?
Has this been updated in the downloads section? I had only seen 067.
-S
Unread post by senso » 17 Apr 2015, 18:55
uploading ....
sephult
Unread post by sephult » 18 Apr 2015, 01:34
Thanks senso I got :)
-S
Thomas Helzle
Unread post by Thomas Helzle » 18 Apr 2015, 13:28
Thanks for the updates.
But I begin to wish for automatic updates now ;-)
Cheers,
Tom
CREDO
Unread post by CREDO » 18 Apr 2015, 19:33
Just to confirm, is manually transferring the old config folder still a valid update method?
Unread post by senso » 20 Apr 2015, 22:43
CREDO wrote:Just to confirm, is manually transferring the old config folder still a valid update method?
yes+++
Unread post by senso » 20 Apr 2015, 22:44
[large]Usine Hollyhock II 2.0.067c RC11 update[/large]
corrected bugs
Randomize Array Display or Set module works only if the module visible
Unread post by senso » 21 Apr 2015, 09:46
[large]Usine Hollyhock II 2.0.067d RC11 update[/large]
corrected bugs
Various package corrections
Users browsing this forum: No registered users and 229 guests
