Usine Hollyhock Update11 (version 1.1.009g) is available for download
Announcements
Unread post by nay-seven » 23 Aug 2014, 14:20
[large]Usine Hollyhock Update 11 ( version 1.1.009g)[/large]
Some of the improvements and fix:
- The listbox module is now opened centered on last selected
- The internal Message module works now in sub patch
- Flag MIDI input ports with MIDI LEARN on or off fixed
- Most of Audio sound card last issues fixed
- Wires from script outlets are pasted correctly now in sub patch
- In the panner module, all the speaker-parameters are now saved
- Fix a XY Pad Preset Manager bug
- Fix the Matrix module Hiding Header causes enable icon to be hidden under top right cell
- Fix the MIDI control of top level patch on/off
- Fix the bad routing of signal in matrix midi 8x8
- Fix the issues about the creation of stuck Midi notes
Can be downloaded in the download area.
See the release notes for more information
To upgrade just copy the content of your old /Config folder within the MacOSX packet or the WIN directory.
Drosera
Unread post by Drosera » 24 Aug 2014, 14:38
Great!
gurulogic
Unread post by gurulogic » 25 Aug 2014, 20:42
looks good! Thanks!
Users browsing this forum: Bing [Bot] and 10 guests
