New version (3.10 beta)
Announcements
Unread post by senso » 27 Jul 2007, 10:08
version [3.10] beta 07/07/27
It's only a beta version, please report comments and suggestions at contact@sensomusic.com
The sequencer chapter in the manual is not yet updated. Soon, we are working on.
Improvements
- New interface design more compact and smoother.
- The sequencer now plays Midifiles on the time line. The same concept than for wave files: Modular Mixing.
- Knob module, can replace faders. To "auto-create" knobs, use the [shift+ctrl+create wire] instead of [ctrl+create wire].
- New audio engine, faster.
- New Conductor Recall implementation, faster. No more audio clicks during the recall procedure for heavy workspaces.
- Channel Filter inlet in the piano-roll to select which Midi channel you want to play.
- The piano Roll now displays all midi event (CC, PC, etc...)
- Copy File button in the sample list for easy duplication of audio files.
- Mouse down outlet in the XY and Surround Panner modules to detect when the mouse is pressed.
- In the sequencer mode, when you are editing a patch, you can automatically create user curves with the command [alt+ctrl+create wire]. It makes the creation of user curves very fast and easy.
Fixed bugs
- Problems with the undo in a patch. Sometime automation curves are lost.
- Hi cpu load with some VST (ie. Taurus)
- most of reported bugs fixed
Users browsing this forum: No registered users and 255 guests
