ArrayArrayArray BrainModular BrainModular Users Forum 2011-08-01T23:24:43+02:00 https://www.brainmodular.org/forums/app.php/feed/topic/3000 2011-08-01T23:24:43+02:00 2011-08-01T23:24:43+02:00 https://www.brainmodular.org/forums/viewtopic.php?t=3000&p=20196#p20196 <![CDATA[set time fade in and out in the conductor]]>
Hello olivier hello everybody.
As i had ever ask i'd love to set not only a single time fade between 2 scenes in the conductor but a time to up and a time to down.
You answer me that it was a too specific function to be implemented because i told you it was for controling light.
But i dicovered that it could be very useful for sound to because at the moment when i recall a scene that crossfade between
2 players for exemple if one get up while the other get down i have a silence during the cross.
it would be good if the player which go up (i speak about level) could have a shorter time than the player which go down.
Does nobody need that ?
Hi, if you really talk about crossfade between two players, maybe look on may patch.
You can customize positions[depending on sample duration] when one player go up while other go down in automatic mode + in crosfade x2 patch you can draw graphical crossfade how fast level increases or decreases.
In Usine I can make better cossfade in real time than in any multi-track editor.
try this:
http://www.sensomusic.com/forums/upload ... er_red.pat
Statistics: Posted by r.erorr — 01 Aug 2011, 23:24
2011-08-01T11:27:34+02:00 2011-08-01T11:27:34+02:00 https://www.brainmodular.org/forums/viewtopic.php?t=3000&p=20167#p20167 <![CDATA[set time fade in and out in the conductor]]> let me think about this feature.
Statistics: Posted by senso — 01 Aug 2011, 11:27
2011-08-01T10:27:36+02:00 2011-08-01T10:27:36+02:00 https://www.brainmodular.org/forums/viewtopic.php?t=3000&p=20166#p20166 <![CDATA[set time fade in and out in the conductor]]> As i had ever ask i'd love to set not only a single time fade between 2 scenes in the conductor but a time to up and a time to down.
Statistics: Posted by joffo78 — 01 Aug 2011, 10:27
try this:
